You need to take the slack out, its not going to start unless you put it at top dead center. Sounds like you need to do the timing belt, its about 30 bux for the belt, and I dont know how to explain the rest, since my dad did mine. I just know that you WILL NOT START until you do, because by cranking, without the cams timed, it will throw everything off, luckily, I beleive this engine is a non-interface engine, so no damage should have been caused, but stop cranking until you do the timing belt! Its pointless because the cams are not in synce with the pistons anymore.
Good luck.
