engine wont crank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2006, 11:13 PM   #1 (permalink)
View klone1000's Photo Gallery
engine wont crank
about 2 days ago i went on a boost run with my 5sfte and the pressure never went above 7psi. When i turned down my road to go to my house the car had cut off. So i took my foot off the clutch and poped the clutch and the car started again but it was running rough. I drove it in to my yard and the car cut off by itself. So i started up the car and it cranked but it was running rough. So i turn it off. For some reason i had a lot of smoke around my underbody kit and smoke was still comming out the exhaust pipe for about 2 min. So i went in the house and said i would check it out in the morning. So the next morning i checked to see if the car would crank and it would not. So i had lift the hood and i seen that the map sensor hose had come off while boosting last night. So i thought that was the problem. I put the hose back on and tried to crank the car again and it sound like it was out of time or something. So i check the timing marks and the marks are correct. So next i check the spark plugs and they were damp with gas so i figured that there was no fire going to the plugs. when i checked the plugs for spark all the plugs had fired while trrying to crank. So i had go to buy a new distributor and the car will still not crank. Do you think that the map sensor coming unpluged while in boost causes the engine to be damaged? I have no clue what to do next. Also can the computer make the car sound like it is out of time? Please help me...
klone1000 is offline   Reply With Quote
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 08:30 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 05:09 PM
