ATF recommendation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2006, 02:15 AM   #1 (permalink)
View DarkSideCelica's Photo Gallery
ATF recommendation
well, i searched but there was no clear answer as most ppl have 5 speed trannies on here... anyways, i wanna do a drain and fill for my auto tranny some time this week or the next...wat's the best ATF for this car? i have a 92 GT.... and how much do i need?
btw, i can't seem to find any DIY for the tranny fluid change... and no pix too ... sorry, but i learn better with pix
DarkSideCelica is offline   Reply With Quote
Old 10-06-2006, 09:41 PM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
the type of oil you need is on the transmission fluid dipstick.
Dexron *sp II or III should be what you need.
If your car requires dextron III you have to use III, but if it requires II then you can use either III or II.
Oh yeah, sometimes flushing ATF will cause your transmission to slip and take a shit. So as a cautionary statement. "Don't fix if it ain't broke on Automatic transmissions"
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-07-2006, 10:44 AM   #3 (permalink)
Gameroom cash: $265140
View shortlid's Photo Gallery
If it has been awhile like over 50k since the ATF was changed. Do not FLUSH the system just drain and refill with Dextron III. You only get 4 qts. out with the drain and fill method and there is still six qts of old in the tourque converter so the additives in the new ATF do not attackj the seals. But if the ATF has been regularly serviced you hav eno worries. BUT DON'T LET OLD ATF GET ANY WORSE. At least change SOME OF IT!!
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
Old 10-07-2006, 11:33 PM   #4 (permalink)
i bought 1 gallon of Dexron III ATF.... is tht enough for the drain and fill?
Old 10-08-2006, 10:21 AM   #5 (permalink)
Wink Just
Ya, just enough!
Old 10-08-2006, 04:29 PM   #6 (permalink)
just got done draining and filling up my coolant and tranny fluid... man, they were brown and black respectively :o i put in one whole gallon of the Dexron III
Old 10-08-2006, 05:09 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Check the fluid level when the engine is hot and running for an accurate reading and make sure you have the correct ammount of fluid. Too little or too much fluid will damage your transmission.
2007 Camry 2.4L 5M
Old 10-09-2006, 03:10 AM   #8 (permalink)
it's on the top most "ding" on the dipstick after driving it around for a while.... is tht alrite?
Old 10-09-2006, 03:24 AM   #9 (permalink)
I am fairly certain you are good to go.
Does your dipstick have hot and cold imprinted between the notches like my Camry? On my Camry the upper pair of notches has hot written between them and the lower set has cold written there. The fluid should be somewhere inside the pair of hot notches.
2007 Camry 2.4L 5M
Old 10-09-2006, 03:26 AM   #10 (permalink)
yup.. it's on the last notch (or ding) before the word "hot"
man, the difference is nite and day
95 camry v6 atf capacity CAMARY 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-16-2007 07:29 AM
Toyota Tranny fluid only? netranger6 2nd Generation (2005+) 11 10-11-2005 02:26 PM
How to: Check ATF level SmokeyWren 2nd Generation (2000-2004) 3 05-02-2005 11:06 PM
Transmission ATF flush REDSOXTICKET Camry & Solara Lounge 6 07-05-2004 05:02 PM
Changed ATF today, and boy did it stinked!! Samsonite79 Camry & Solara Lounge 5 05-27-2004 08:52 PM
