Running rough @ WOT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2006, 06:52 PM   #1 (permalink)
View celicadawgs's Photo Gallery
Running rough @ WOT
Hi guys, new to the forum.
OK, so all has been fine with the Celica for a few years now.
94 Celica GT 5 speed 2.2L 145XXX miles
Mods: Aftermarket intake installed about 1-2 months ago
New spark plugs installed 5-6 months ago
I can start the engine and it will run fine @ idle. (doesn't mis) If I give it gas it "coughs" and acts as though it's going to die.. If I slowly open the throttle it will rev to redline just fine, No problems at all. I have to be very gentle on the gas, anymore than 1/3 of the throttle @ idle or 1/2 throttle above 3000 rpms and the engine coughs.
I also notice hearing a sucking noise when goosing the throttle plate. I don't think it's a vacuum leak, just the intake sucking air in. I think this is normal.
Now, If I remove the intake and goose the throttle to near WOT while it "coughs" a puff of white smoke will come out of the intake. My first thought when I saw this was a faulty intake valve, but I don't really think it's mechanical becuase it doesn't mis except when it "coughs." I'm wondering if the fuel system isn't dumping in to much fuel for some reason?? Is this normal with our celicas? Is there a common problem I should start with?? If it's not fuel related what else could cause the problem?? Thank in advance for your responses.
celicadawgs is offline   Reply With Quote
Old 10-06-2006, 07:39 PM   #2 (permalink)
engineer in training
Gameroom cash: $141655
sounds like your ignition timing is off or your cap and rotor need replacing (do the 94 5sfes have a cap and rotor?) anyway, check and see if you need to replace them.
Old 10-06-2006, 08:59 PM   #3 (permalink)
Thank you.
I do beleive it has a distributor. I will check the timing.
Is there anyway to test the distributor to see if it's shorting internally??
I know check the contacts, use a timing gun, make sure all connections, etc are good..
What is the resistance of the coil suppossed to be? Thanks again
Old 10-06-2006, 09:30 PM   #4 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
Do a complete tune up too while you are at it, it probably needs it.
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-06-2006, 10:29 PM   #5 (permalink)
Ok, I did a search and couldn't find any specs for the coils.
I assume they should change resistance slightly when warm.
If I can't find specs I'll just pull a coil wire and check spark kv.
Old 10-07-2006, 06:28 AM   #6 (permalink)
if its a cap and rotor then the cap and rotor are most likely corroded and that will cause exactly what you are describing. I doubt the coil is bad so start with the simple before you go testing the coil
Old 10-07-2006, 08:18 PM   #7 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
it has a distributor (cap, rotor)
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 10-07-2006, 09:30 PM   #8 (permalink)
Well I tested the spark tonight and found that I had a nice hot blue spark. I thought what the hell, I'd pull the cap and check the distributor for corrossion. I found the rotor was pretty corrodded at the tip, so I replaced it. Now I have a red spark that only sparks occassionally. I thought maybe it was a bad rotor, so I exhanced it for another. Same thing. I then stepped on the old rotor and and cracked it, so I can't put that back on.
All I did was replace the rotor, why I went from a good spark, to nearly no spark and no start is beyond me.. Pretty hard to mess up isn't it? Unless I'm overlooking something.
Ok, Once I fix the problem I somehow created I'll be back to square one.. For some reason @ WOT or near it the cylinders fill with fuel. I did this while checking spark (before breaking the old rotor) and the spark stayed a nice hot blue color, no change. Plugs are obviously fouling, but replacing them isn't going to help becuase it's just going to happen again..Which makes me feel it's a fuel issue. For some reason when you goose the throttle and open faster than "gently" it seems like the chamber fills up with fuel..
Injectors staying open maybe?? Intake leak not allowing enough air into the chamber??
running rough 4 cyl 68Malibu 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-21-2006 05:45 PM
91..running rough Bobbie 4Runner Lounge 3 11-05-2005 02:32 AM
91 tercel running rough Help girlietercel Tercel, Paseo, Starlet, and Sera Forum 3 12-14-2003 02:07 AM
