couple easy questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 03:27 PM   #1 (permalink)
View DarkSideCelica's Photo Gallery
just couple easy ones guys
1. how do i take off the hubcaps? the ones on Hondas are secured using the lug nuts, but tht's not the case for the ones on the celica.... do i just pull it off to get acess to the lug nuts?
2. I'll be doing a motor oil change...where's the oil filter and drain plug at? i'm guessing the oil filter is the one on the passanger side, just below the head and alternator? and what weight oil do i use? thanx
DarkSideCelica is offline   Reply With Quote
Old 10-10-2006, 04:33 PM   #2 (permalink)
View 430hpToy's Photo Gallery
1. give those hub cabs a yank! LOL
2. what year is the celica? if it's a 2.0 or 2.2 from 80's-90's the filter will be right on the front of the block. the drain plug is on the bottom of the oil pan(12mm maybe 14mm can't remember). i'd go with a 10w30 motor oil!
8. No commercial/business/website promotion in Signatures. The only URLs allowed in signatures are to your own car's personal website or another Autoforums.com website. No exceptions!
430hpToy is offline   Reply With Quote
Old 10-10-2006, 06:38 PM   #3 (permalink)
^^thanx for the reply..
man, no wonder the hubcaps are cracked.... ppl keep yanking them lol
i have a 92 GT auto....2.2L 5sfe.... i saw the filter, but was skeptical cos it's so obvious and easily accesible... i work on Hondas, and the oil filters are on the back of the block at a weird angle
Old 10-10-2006, 08:00 PM   #4 (permalink)
btw, the filter screws in and out like a normal screw rite? i mean clockwise to tighten, and anti-clockwise to loosen
Old 10-11-2006, 02:23 AM   #5 (permalink)
just did the oil change just now at 9 pm :p
everything was easy, except the oil filter... it was all metal, and didn't have the rubber grip thingy on the top....tht $hit was sooo stuck, i drove to a nearby autozone to buy an oil filter remover..the guy told me to save my money and should instead poke a screwdriver thru the filter and use the screwdriver to turn it... went back, did tht, voila!
i used castrol GTX 5w30 oil
Couple of Questions + Concerns '02 Camry LE 2.4L L4 HarrisH 5th & 6th Generation (2002-2006 & 2007-2011) 6 12-02-2006 10:14 PM
New Tacoma owner. I got it over a week ago... couple questions NB-Tacoma 2nd Generation (2005+) 16 09-28-2006 05:49 PM
Couple of questions regarding my 07 CE greggerojr 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-13-2006 05:55 AM
Couple of questions fistofmeat Archived Corolla threads 9 07-30-2006 04:16 AM
Some easy mechanical questions - 1991 Toyota Pickup beansbaxter 89-95 Toyota Pickup/Hilux 6 07-24-2006 12:29 PM
