Crankshaft Pulley Holder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2006, 12:58 PM   #1 (permalink)
View llp773's Photo Gallery
I am trying to change the timing belt on a 1990 celica 1.6L, 4S-FE engine.
Anyone have suggestions on holding the Crankshaft Pulley besides purchasing the Toyota Specialty Tool (which I have heard costs a couple hundred dollars)?
Anyone know of a universal tool to hold the pulley(such as a Schley tool)?
I tried the method in the Haynes manual where a couple of screwdrivers are used and the only thing I got out of that were scraped knuckles......
Any other suggestions?
Thanks,
Lou
llp773 is offline   Reply With Quote
Old 10-16-2006, 03:28 PM   #2 (permalink)
View 430hpToy's Photo Gallery
you try hitting it with a good impact???
my cousin discovered a unique way of getting the bolt out, but you risk damaging the teeth on the starter. lol
8. No commercial/business/website promotion in Signatures. The only URLs allowed in signatures are to your own car's personal website or another Autoforums.com website. No exceptions!
430hpToy is offline   Reply With Quote
Old 10-16-2006, 10:30 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
get a chain wrench
Old 10-17-2006, 04:12 PM   #4 (permalink)
View aero92's Photo Gallery
not really.
1.- Spray WD 40 on the inside of the pulley.
2.- Get one of those cheap Harmonic Balancer pullers mine costed me 7 bucks
3.- Throw out the screws, theyre no good
4.- Thread Screw on puller tool, then place protective tip over screw
Here's the trick
I used a long 6 inch clamp and a pipewrench, grasp the puller and pulley together
5.- Thread puller screw a few turns, then softly hit the pulley to remove it slowly. Repeat turning
I did mine in about 3 minutes. Spent half a day looking for the tools.
P.S.
To remove screw just place a 1/2 inch ratchet with 1/2 inch socket and crank starter a little bit. Bolt comes out immediatelly. Dangerous if you're holding it by hand.
Let the starter do the work.
Good luck!!!!
aero92 is offline   Reply With Quote
Need advice for crankshaft pulley bolt removal BIG A Camry & Solara Lounge 13 08-13-2011 10:31 AM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 10:20 PM
Best way to remove crankshaft pulley nut (flywheel inspection cover?)? awmccready Camry & Solara Lounge 5 11-26-2004 12:58 PM
4th gen 89 gts crankshaft pulley bolt Horseflydf Celica Forum 1 09-16-2004 02:16 AM
