losing coolant! help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2006, 01:22 AM   #1 (permalink)
View DarkSideCelica's Photo Gallery
well, this just happened just now... i came back home after driving 25 miles from work, and noticed tht my radiator fan was running after i switched off the car (key was on position... i turned off the car and realized i had left the window down:p)...
i popped the hood, and saw coolant leaking from the bottom of the car... it was near the tranny area... i looked again and it seems tht the coolant was leaking somewhere in between the distributor cap, the air box and tranny dipstick... it was in between all tht, and below the top radiator hose...i filled it up with coolant, checked all the hoses and let the car run, but the coolant level seemed fine... do u think it's a leak tht happenes only when the engine is at operational temp? and is there a hose in tht area i described? thanx
btw, i have a 92 celica GT auto
DarkSideCelica is offline   Reply With Quote
Old 10-17-2006, 02:03 PM   #2 (permalink)
View OEMonkey's Photo Gallery
Just pressure test the cooling system or have a shop press. test it. takes 5 secs, if there's a leak you'll definitely see where it's coming from.
OEMonkey is offline   Reply With Quote
Old 10-18-2006, 02:44 AM   #3 (permalink)
cool... i'll bring it to the shop then... hope it'll last me till sat :o i gotta drive tht car everyday to work
funny thing is the coolant does NOT leak when i drive to the office... i would check the coolant level and look for any drips during lunch, but NOTHING..... only happens after i get home... any idea what might be causing this leak? i'm stumped
Alltrac engine overheating and losing coolant bhawkins Celica Forum 2 10-13-2006 12:00 PM
Do you need to flush the coolant during the water pump change? NewRacer 3rd & 4th Generation (1992–1996 & 1997–2001) 7 09-07-2006 04:54 PM
1996 Camry radiator coolant disappearing? RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 8 06-21-2006 01:13 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 10:03 PM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-12-2004 12:03 AM
