Knockin' - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2006, 12:20 PM   #1 (permalink)
Mr. Sir's Avatar
View Mr. Sir's Photo Gallery
Knockin'
Hi Ladies and Gents!
I just bought a '94 Celica GT for my wife.A little bit beat up but runs strong.Now the problem is it's knocking in the back.I've changed the structs links bushings etc. spent $700 on it and it's still knocking. What is it?
Pete
Mr. Sir is offline   Reply With Quote
Old 10-19-2006, 02:51 PM   #2 (permalink)
View crash910's Photo Gallery
....does it happen when you brake?...if so then it might be a loose brake caliper
Sam
crash910 is offline   Reply With Quote
Old 10-19-2006, 05:29 PM   #3 (permalink)
Mr. Sir's Avatar
I meant the knocking when i go trough pot holes or cracks on the road. Like when you have a really bad suspension.Like it hits hard on something ..I can't really tell....i hope u know what i mean.
Old 10-19-2006, 05:41 PM   #4 (permalink)
View toyomoho's Photo Gallery
A few places to check are the stabilizer bushings where it bolts to the frame, and upper shock mounts. The rubber in the mounts can break down over time. Have someone listen at the top of the shock mount when you drive over a bump, etc.
Old 10-20-2006, 09:44 PM   #5 (permalink)
get new struts. i can almost garenntee thats your noise
Old 10-20-2006, 09:45 PM   #6 (permalink)
edit. sorry i didnt realize you changed your struts..i thought it read strut links...you should use grammar :P
Old 10-21-2006, 01:26 AM   #7 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
Clean your trunk out. Shit in the back can cause that. If you have a HB then it could be the lid that's causing the noise. Check your exhaust system it could be slapping the unibody. For example, the muffler may slap the trunk compartment because of bad hangers.
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
