steering wheel problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2006, 09:36 PM   #1 (permalink)
View DarkSideCelica's Photo Gallery
whenever i turn my steering wheel to either side (even the smallest turn), i hear this whirring sound coming from the engine bay and the car shakes a bit.... it's even louder and shakes harder when the motor is still cold... PS fluid is good (but not sure how old it is tho).... at what intervals do i need to change the PS fluid anyways? i think it's 100K rite?
or could it be my side motor mounts going bad?
DarkSideCelica is offline   Reply With Quote
Old 10-21-2006, 01:30 AM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
Your power steering pump is taking a shit. Mine does the exact thing. Power steering pumps blow in the celicas. I'm in the market for another one. Changing fluid will help for a little bit, not a permanent fix. 3-4 months.
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-21-2006, 02:18 AM   #3 (permalink)
crap... how much is the part, and is it difficult to replace? any DIY?
Old 10-21-2006, 09:31 AM   #4 (permalink)
The part is $50 off of ebay...... but I'm too cheap and don't wanna go through the brain damage of returning it if happens to be wrong or bad.
$10 at the scrap yard. That's where I plan to get mine. I think it is a DIY. I'll do the picture thing when I get around to finding a donor.
Old 10-25-2006, 03:58 PM   #5 (permalink)
here's wat i did guys...
last time, i just topped off the fluid, and it still made tht noise... today, i actually pumped out everything from the reservoir and added in dexron III fluid.... noise went away for the most part, but still some noise...
AND THEN, i saw fluid leaking from the bottom of the car... it was the fluid tht i JUST put in... it was leaking somewhere in between the cat and passanger front wheel... any ideas?
Old 10-25-2006, 04:39 PM   #6 (permalink)
View tankd0g's Photo Gallery
If it's really pouring out the hose may have cracked. If it's just a small leak well that's probably the seal on the pump.
tankd0g is offline   Reply With Quote
Old 10-25-2006, 04:56 PM   #7 (permalink)
it drips a few times (maybe 5-7 times) a minute... it might be a hose, but i dun have the chance to jack up the car to see it cos i'm at work... how diff is it to replace the seal on the pump?
Old 10-25-2006, 08:41 PM   #8 (permalink)
ok... more analysis.... the fluid ONLY leaks out if i turn the wheel all the way to one side.... so, it only leaks under high pressure... a seal maybe? it still leaks at the same spot btw
Old 10-25-2006, 11:10 PM   #9 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
If it's leaking from between the cat and the front wheel, then it sounds more like a seal on the rack itself.
Or possibly the fluid is dribbling down the hose from somewhere higher.
- Stepho
stepho is offline   Reply With Quote
steering wheel whiteae92 Archived Corolla threads 7 05-06-2006 10:16 PM
82 Toyota pickup 4x4 - steering problem Kiijo Pre-88 Toyota Pickup/Hilux 4 10-17-2005 11:58 AM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
Toyota Steering Wheel edgarchan Camry & Solara Lounge 5 07-27-2004 11:29 AM
How to paint the steering wheel cman2000 Camry & Solara Lounge 3 02-29-2004 01:53 PM
