What are my options for Power steering????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2006, 01:35 AM   #1 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
My 1992 celica st 's power steering pump is taking a shit. Making gawd awful noises and sounds like a cat stabbing everytime I start my car and turn the wheel slightly. So I know I need a pump.
Question:
What toyota models can I take a power steering pump from? For example (1992 celica gt???) Corolla? camry? and what years?
Junk yards will be where I'll find one but celicas are hard to come by.
Thanks in advance!
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-21-2006, 04:40 PM   #2 (permalink)
Bump bu bump
Old 10-22-2006, 11:00 PM   #3 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
I'm out of my age bracket (I prefer older, RWD cars) but wouldn't any Toyota with the same engine family be a good donor?
Eg 3S-GE, 3S-GTE, 1S, 2S, 5S-FE should share the same power steering pumps.
Like wise for 4A, 5A, 7A, etc.
Knowing Toyota, the A and S engines probably use the same pump with different brackets.
- Stepho
stepho is offline   Reply With Quote
Old 10-23-2006, 12:08 PM   #4 (permalink)
08 XR
iTrader Score: 6 reviews
View MrJones's Photo Gallery
uh try adding power steering fluid, same thing happend to my buick.
Originally Posted by ECale3 View Post
It's not about the destination, it's about the drive.
MrJones is offline   Reply With Quote
Old 10-23-2006, 12:43 PM   #5 (permalink)
I added fluid..... My pump is taking a shit. I need a new pump.
Old 10-23-2006, 03:17 PM   #6 (permalink)
View DarkSideCelica's Photo Gallery
same prob here... first turn after starting up my car always sounds like a cat getting choked :o i might just let the shop do the install..... OR, if u could get a DIY posted, i'll try it out too :p
DarkSideCelica is offline   Reply With Quote
Old 10-23-2006, 04:20 PM   #7 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Perhaps the belt is worn or loose ??? (Trying to imagine the sound you're describing....heh)
PhantomS is offline   Reply With Quote
Old 10-23-2006, 04:55 PM   #8 (permalink)
Gameroom cash: $103420
View 90celica's Photo Gallery
can't u just drive without the power steering!!!! ??
it is a good work out for your arms!!
just remove the belt
1990 Celica GT - work in progress
1994 Tercel
90celica is offline   Reply With Quote
Old 10-24-2006, 01:18 AM   #9 (permalink)
It's safer with power steering. My belt is new and has proper tension. I'll post a DIY, when mine really takes a shit. I just gotta make sure I get my information first.
Thanks guys!
Old 10-25-2006, 10:24 AM   #10 (permalink)
View liplip's Photo Gallery
It could be just the high pressure power steering hose.The one connected to the pump.When i bought my 90 celica gt, there was a leak.I took another hose from another celica but turned out that hose also had holes.I finally bought a high pressure hose for $100 and it hasn't leaked in 3 weeks now.
liplip is offline   Reply With Quote
Old 11-18-2006, 07:20 PM   #11 (permalink)
Okay guys, I went to the junkyard and found a 4-afe in a geo prizm which has a lot less miles on it than my celica. The power steerig pump was the same so I put the pump on my celica... two bolts and disconnecting the hoses pulls it off the car Nothing too big. After putting the newer pump in my car every problem was fixed.
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Steering troubles... grndslm Archived Corolla threads 5 10-31-2006 12:05 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
Leather steering wheel cover options ?? CraigW General Discussion 2 10-20-2004 11:37 AM
