JDM 3SGE Engine fires but doesn't run - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2006, 08:11 PM   #1 (permalink)
View wooly55's Photo Gallery
I have recently installed a replacement JSM 3SGE (1988 Celica/Camry?)) engine in my 1986 Celica GTS. The JDM engine does not have an EGR valve and I have bypassed the vacuum hoses to the charcoal cannister etc but I believe I still have a vacuum leak that is preventing the car from idling and running longer than a few seconds on the cold start injector. Does anyone know where the vacuum line that comes out of the front of the throttlebody (single vacuum port) runs to on a JDM engine?
..Any other ideas on possible problems?
I have fuel to the fuel rail, changed out the distributor and coil-getting spark..service engine light on dash lights up...I tried to do a diagnostic but I think battery was too discharged..
wooly55 is offline   Reply With Quote
Old 10-22-2006, 09:01 PM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
a weak fuel pump may cause those symptoms. First, give your battery a full charge.
1993 Celica ST-------------- Successfully swapped A 5afe 1.5L works great!
1992 Celica ST-------------- Daily Driver 236,000 miles currently
1991 Celica Convertible---- Father's daily driver
thousand_five is offline   Reply With Quote
Old 10-25-2006, 08:02 PM   #3 (permalink)
sbettencourt's Avatar
View sbettencourt's Photo Gallery
if the car is only running for a few seconds, sounds like it's not geting the maf signal to the ecu. a vacuum leak wouldn't stop the engine from running altough very rough...
sbettencourt is offline   Reply With Quote
Old 10-26-2006, 12:34 PM   #4 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
a big enough vacuum leak can cause the engine to start and then die, that happened to me went the two vac line going to the power steering came off.
89CelicaGTTurbo is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Total cost for a new 7MGTE MKIII JDM Engine from Japan? xpeed Supra Forum 11 03-31-2006 07:30 PM
Header for 1987 celica with 3SGE engine bigchips Celica Forum 2 09-18-2005 09:32 AM
JDM engine wiring harness Mr.Two MR2 Forum 4 03-26-2005 06:52 PM
