Rough running when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2006, 04:22 PM   #1 (permalink)
View ragg's Photo Gallery
I have friend with a 94 celica and after starting it runs rough at idle and under acceleration until its warm. usually about 5 to 10 minutes. After this it runs fine , idles fine.
I don't know anything about celicas so any ideas would be greatly appreciated.
Whats the process for checking the fault codes (if there are any).
thanks
ragg is offline   Reply With Quote
Old 11-05-2006, 12:17 AM   #2 (permalink)
anyone?????? any ideas?
What tells the car the engine is up to temp and adjusts the idle ? iac and coolant temp sensor?? whats the best way to check if these are working properly?
Old 11-05-2006, 01:00 AM   #3 (permalink)
View A Diddy's Photo Gallery
i have an idea! Let the car warm up like everyone else does. Fluids (mostly coolant) have to get to the right temperature. On your dash u will see a coolant temp gauge. When you turn on your car it is on the C for cold side, you want it to move off the all the way cold and warm up a bit. After you drive it for like 5 mins after a warm up the needle should be in between the C and the H for hot. At this point coolant temp is where it should be and car will run normally.
2004 G35 6MT
1991 3sgte Celica GTS
A Diddy is offline   Reply With Quote
Old 11-05-2006, 03:24 AM   #4 (permalink)
Not practical to let the car warm up for 10 mins before it gets driven. not like the climate is cold here in australia.
The car misses and jesks and stalls even if you let it warm up at idle for 5 mins before driving!
There is definately a problem and its not because the fluids are cold
Old 11-05-2006, 01:14 PM   #5 (permalink)
are u getting any codes?
2004 G35 6MT
Old 11-06-2006, 02:00 PM   #6 (permalink)
View Mondo131's Photo Gallery
thanks
Same problem. Make sure your distributor and rotor contacts arnt coroded.
Mondo131 is offline   Reply With Quote
Old 11-09-2006, 06:46 PM   #7 (permalink)
I have traced the problem back to the number 2 cylinder . checked the spark plugs and leads , which are all fine.
next check is the injectors and a compression check
No fault codes!
running cold wormhole Camry & Solara Lounge 19 11-01-2005 06:23 PM
84 22R-E Rough running No power Super-D-38 Celica Forum 13 02-27-2005 08:48 PM
