Resealing The 5SFE Distributor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 02:25 PM   #1 (permalink)
View unuk's Photo Gallery
Hello,
I'm working on a 97 Celica GT w/ the 5SFE 2.2 motor.
It appears the distrubutor is leaking oil from the center shaft seal visible with the distro mounted on the engine. It's a slow leak, but obviously not a good place to be leaking oil.
The car died, cleaning up the inside of the distro and replacing the cap/rotor allowed it to run again, but I need to go back in and fix the leak itself in the near future.
How bad is it to replace the shaft seal? Is there a seal kit for the distro and will it require any special tools to get the distro apart and/or install the seals?
Thanks,
-U
unuk is offline   Reply With Quote
Old 11-02-2006, 02:58 PM   #2 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
This happened to me as well.
You will need to replace the lower part of the distributor because there are no seal kits from Toyota. You dont need to get a new distributor just the lower housing and then swap some of the parts over. Not hard at all.
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 11-02-2006, 03:11 PM   #3 (permalink)
Gameroom cash: $147537
KBox sell them and I got bearing and seal for it. You'll need a press to disassemble the distrubutor.
http://www.toyotanation.com/forum/t152182.html
Old 11-03-2006, 10:37 AM   #4 (permalink)
Once upon a time...
View kbox's Photo Gallery
We have the full rebuilt kit..
http://www.kbox.ca/catalog/product_i...roducts_id=184
Jody Collicutt - [color=blue]'87SC J-Spec DLI AE92 - 246,246 kms and counting...
kbox Engineering www.kbox.ca
kbox is offline   Reply With Quote
95 5SFE won't start - a question re: distributor 500KCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 36 04-19-2006 08:13 PM
Turning the distributor for ignition timing on a 96 Gen3 5SFE basil 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-21-2005 02:39 AM
96 Camry 5SFE won't start after replacing distributor o-ring basil 3rd & 4th Generation (1992–1996 & 1997–2001) 5 09-20-2005 11:52 AM
5sfe distributor rebuild kit? profuse007 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-16-2004 10:37 PM
Distributor on 5SFE USFputz 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-07-2004 04:22 PM
