Does 3SGE engine require antifreeze to run? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 11:57 PM   #1 (permalink)
View wooly55's Photo Gallery
I have attempted to start my Celica without antifreeze in system? Does the ECU sense there is no fluids and therefore doesn't fire?
wooly55 is offline   Reply With Quote
Old 11-02-2006, 11:59 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
no, antifreeze isnt required in any cooling system, describe what it does when you try to start it
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 11-03-2006, 02:48 AM   #3 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
check for codes. i've started my 3sge with out coolant before so there's something else wrong with the car.
89CelicaGTTurbo is offline   Reply With Quote
Old 11-04-2006, 06:59 PM   #4 (permalink)
The cold start injector injects fuel and the car starts for a few moments then dies. There have been a few suggestions for a fix but none have worked. I am now thinking there could be an issue with the curcuit opening relay that controls the fuel pump. An earlier response to my of my threads indicated fuel pump pressure could be an issue. As I have a second Celica I will harvest the relay and see what happens? I am also checking the vacuum hose connections etc. and for other vacuum leaks.
Old 11-06-2006, 02:25 PM   #5 (permalink)
View TubRog5's Photo Gallery
You might just have a bad fuel pump. I had this same issue with my 85 Celica when I got it. It would start then just die. I changed the fuel pump and that problem went away.
TubRog5 is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
3sge high engine speed GT-Tyn Hardcore Tech and Competition 29 09-04-2004 12:32 PM
3sge 16v tvis n/a engine computer box johnny Hardcore Tech and Competition 3 03-27-2002 09:55 AM
