Hello..
I recently got a 3sge first gen to swap in my ae92 corolla. I already got the mounts modified but i want to make this first gen 3sge turbo. I want it for dayly use and weekends track.. my power goal is 230-300hp .. keeping power steering and ac.
I am getting this parts.:
new crank
eagle rods
8:5 pistons
"ebay" turbo header/downpipe
arp head studs
lightweight flywheel/ act clutch
oil cooler and filter relocation
tvis eliminated (just in case it gets pushed in to the head)
Now i need to know about this parts..
----------------- Throttle body-----------
The factory 3sge first gen tb is 2.18" diameter.. and they told me that is a good set up to use a bigger one but no more than 2.5... the told me that the mustangs 5.0 uses a 2.36" and it would be a better choice. (anyways iam not going to use the stock turbo ecu). Is that a good idea???
---------camshafts------------
Do the stock 3sge cams.. are capable of 250+ hp?... which would be a better set up.. but not to agressive? i dont want to sacrifice to much low end..
----------TURBOCHARGER------------
Which turbo is good for that set up? how can i get the trim sizes etc etc. i want good high rpm but not to much lag.. but something better than the stock. what are my choices?
-----TRANSMISSION------
Which FWD manual trannny will work? ... i heard something about an 5sfe tranny.. do they handle 230-250 hp? .. any suggestions..
I dont want to get a jdm 3sgte engine .... i want to rebuild this one and make it a beast
Please... give me some suggestions..
THANKS...
