Camber Adj. on 83 GTS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2006, 10:14 PM   #1 (permalink)
gwl
View gwl's Photo Gallery
Just got a 83 GTS coupe, all original from an original owner. It has 113,500 miles on it. Just wondering what would cause in the inner side on both rear tires to wear - more so on the right tire. Of couse it has the independent rear suspension. I'm thinking it needs new suspension parts ie bushing, shocks.... Or do you think it just a 4 wheel alignment.
TIA
gwl is offline   Reply With Quote
Old 11-14-2006, 10:32 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
do a ride height and align check first
Old 11-14-2006, 10:54 PM   #3 (permalink)
gwl
Whats a ride height check? I'm thinking the distance from the ground to the top of the wheelwell. Do you have any specs?
TIA
Old 11-19-2006, 08:08 AM   #4 (permalink)
BrightTundra04's Avatar
View BrightTundra04's Photo Gallery
on the GTS shoud be about 26" from the ground to the top of the wheel arch. There are two bolts that hold the center section in place if they come loss that allows the section to fall causing a negative camber condition which is what your describing. Id start by checking those bolts to see if they are tight. At some point the owner may have had diff work done and the person who did the work didn't get those bolts tight. the other thing that might cause that is if there is a problem with the axles because of the design of the rear the axles replace an upper arm so they position the tire and the lower arms help "fine tune" how the whell sits.
BrightTundra04 is offline   Reply With Quote
Old 11-20-2006, 05:10 AM   #5 (permalink)
gwl
Thanks for the response. I will check on the two bolts to see if they are tight. On the axle, what should I be looking for to see if the axles has any problems?
Old 11-20-2006, 06:08 AM   #6 (permalink)
look at the rubber boot to see if they are torn to indicate a problem.
Old 11-20-2006, 09:05 AM   #7 (permalink)
gwl
The right side looks to be slightly torn because I do see some dirt collecting around the boot area. The left boot looks pretty clean. Also, the tire on the right is wearing a little more than the other tire. But I see what you mean, if there are any wear in the CV joints that would make the tires sit a little different.
Old 11-20-2006, 10:28 AM   #8 (permalink)
View RVAMitchell's Photo Gallery
check this website
www.celica-gts.com/forums/index.php
great place for 3rd gen celi info.
they have helped me with 85 celica, taught me most of what I know, hahaha.
RVAMitchell is offline   Reply With Quote
Old 11-20-2006, 12:38 PM   #9 (permalink)
gwl
yeah, I'm reg on that site too.
AE86 GTS to SR5 same as AE92 GTS to SR5 Conversion? OwnerOfReality Archived Corolla threads 34 08-02-2006 04:37 AM
tC or Toyota Celica! switchex 1st Generation (2005-2010) 21 05-06-2006 08:22 PM
83 Celica Supra GTS electrical problem MrPipes Celica Forum 3 08-14-2004 04:21 PM
85 celica gts headlights on a 83 celica gt? will it work? ubongen Celica Forum 1 07-30-2004 01:41 PM
Camber scam or paranoia? BenG Camry & Solara Lounge 8 04-26-2003 12:49 PM
