3S-FE vs 3S-GE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2006, 02:31 PM   #1 (permalink)
View Jester's Photo Gallery
Gen5 3S-FE vs 3S-GE
Question for all you engine guys out there..... I used to have a 90GT back in the UK that had a 3S-GE engine that I had done various things to. I have since sold that and moved over to the States and now have in my posseion once again a 90GT but it has a 5S-FE engine in it which I am finding hard to find parts to modify it. I have however found plenty of 3s-FE engines for sale here which would be nice to set up on my bench and modify until the point that it needs to go into the car. My question is, the only difference I can see between the 3S-FE and the 3S-GE engine is the compression ratio.... is that the only difference and hence if I boost the compression ratio that should then kick out the same power as a standard 3S-GE?
Sorry about the long winded ness of the question but thought it best if you had all the facts!!!!
Cheers
Jester is offline   Reply With Quote
Old 11-21-2006, 05:45 PM   #2 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
I will try to help you out a little
First the difference between a 3sfe and 3sge
3sfe on cam drives the other, 3sge cams run seperate
3sfe lower horsepower, 3sge higher horsepower
3sfe seen as "economy motor", 3sge seen as "sports" motor (TVIS)
If you are just looking for a little more power add and intake and exhaust to your car with the current motor. If you are looking for a "little" more power you should look into swapping in a 3sgte which is a 2.0 litre turbo motor found in the alltracs and turbo MR2's.
If you have anymore question just post them up
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 11-24-2006, 12:35 PM   #3 (permalink)
Insanity makes more sense
View WVcamry3sfe's Photo Gallery
the 5sfe/3sfe engines are very reliable, but not very powerful. the extent of the work you can realisticly do to an fe head is limited to exhaust, intake, and ignition. I have a 3sfe in my 90 camry. I have done exhaust work to it, pacesetter makes a set of headers for the 3sfe engine. I am not 100% sure on this, but I think the 5sfe has the same flange for the exhaust manifold, so maybe the pacesetter headers could work on your 5sfe.
the fe heads are not good candidates for large amounts of HP gain however... turbocharging is not something these engines can handle without a serious engine rebuild. If you want to stay normally aspirated look into a 3sge, sounds like you already have experience with that engine. the 3sgte is also a very similar engine... only major difference is the turbo obviously.
WVcamry3sfe is offline   Reply With Quote
Old 12-01-2006, 02:10 AM   #4 (permalink)
View WH95TE's Photo Gallery
You can always go turbo with your 5sfe. Theres guys over on the 6th gen forums making 230+ with it.
WH95TE is offline   Reply With Quote
Old 12-06-2006, 11:24 PM   #5 (permalink)
TN User
View adamderry's Photo Gallery
The 3sge has a totally different head than the 3sfe, the ge head is identical to the 3sgte head, just different springs and maybe different valves. The 3sfe has basically the same head as a 5sfe, but like I say, the ge has a wider head, way bigger intakes ports (that are shaped just beautifully by the way), and is an engine far more suitable to performance than the sfe. If you swapped in a ge, you could shoot it with nitrous and make more hp than a stock 3sgte, and for quite a bit less work.
adamderry is offline   Reply With Quote
Old 12-09-2006, 07:45 AM   #6 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Not just the compression ratio. Pistons, cams, intake and exhaust ports, both manifolds and engine tuning.
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 12-14-2006, 10:27 PM   #7 (permalink)
View mark_b_uk's Photo Gallery
Gen5 Different specs for UK models
The 5th generation Celicas were available in the UK from 1990.
In the UK, two variations of 2 litre Gen 5 Celicas were available at launch - the 2.0GT 5 speed and the 2.0GT Automatic. These were followed shortly afterwards (October) by the awesome GT-4 (all trac in US).
Celica Gen5 2.0GT (Manual)
ST182 - 3S-GE Engine
Capacity 2.0 litres Normally Aspirated, Power 158 bhp @ 6600 rpm, Torque140 ftlb @ 2800 rpm, 0-60 7.9 seconds, Top Speed 137 mph, Fuel Economy 28.5 mpg, Fuel Capacity 60 litres, Wheel Size14" (205/60 Tyres)
Celica Gen5 GT4
ST185 - 3S-GTE Engine
Capacity 2.0 litres Turbocharged, Power 201 bhp @ 6000 rpm, Torque203 ftlb @ 3600 rpm, 0-60 6.7 seconds, Top Speed 143 mph, Fuel Economy 24.4 mpg, Fuel Capacity 68 litres, Wheel Size 15" (215/50 Tyres)
The 3S-FE WAS NEVER AVAILABLE IN THE UK.
3S-FE and 3S-GE mean: 3 is 3rd generation, S is the S series engine, F is economic head, G is performance head, E is electronic fuel injection. So 3S-GE = 3rd gen of S series engine with performance head and electronic fuel injection.
mark_b_uk is offline   Reply With Quote
Old 12-15-2006, 10:02 AM   #8 (permalink)
Gen5
Thanks for all the help and advice guys, and yes Mark_b_uk I know the 3S-FE was not available in the UK..... i live in the states now which it is available in and the GT does not come with the 3S-GE here in the states..... I have however found a seller who has a 3S-GE so that is now winging its way to me and hope to have it installed soon.... cheers
Old 12-15-2006, 12:00 PM   #9 (permalink)
View Hanmin's Photo Gallery
Grats, I have a 3sge engine, and with such a light car its pretty quick=] cant even get its full potential out because of bad tires =[
Hanmin is offline   Reply With Quote
3SGE generation differences DodgeGarage Hardcore Tech and Competition 8 01-29-2012 04:16 PM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
What will be needed for GE head on FE? Kr0n1k Archived Corolla threads 25 10-08-2006 01:08 PM
fe to ge fistofmeat Archived Corolla threads 20 08-03-2006 10:06 PM
FE vs. GE MattL Camry & Solara Lounge 4 07-31-2006 02:58 AM
