Drive Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2006, 06:53 PM   #1 (permalink)
View traysab's Photo Gallery
Drive Belt
Can anyone tell me how to loosen the drive belt tension on my 2002 1.8 Celica
Thanks, Trey
traysab is offline   Reply With Quote
Old 12-02-2006, 09:42 PM   #2 (permalink)
View toyomoho's Photo Gallery
One place to look would be the alternator. Loosen the alternator bracket pivot bolt closest to the engine block. Then there should be an adjusting nut on the opposite side of the alternator. This nut should face the radiator at an upward angle. You will need to loosen another bolt below the adjusting nut before turning the adjusting bolt.
Some cars have an idler pulley with an adjustment nut on top.
The PS belt is loosened at the PS bracket.
Old 12-03-2006, 08:46 PM   #3 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Why? what are you trying to accomplish.
Make sure it isn't too tight- you'll wear out the bearings.
FYI!
Blane is offline   Reply With Quote
Old 12-06-2006, 07:32 PM   #4 (permalink)
Need to replace the belt................Trey
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Replace Drive Belt On 2002 4cyl Camry nickgs4 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-29-2006 02:32 AM
under drive pully belt hksboost Camry & Solara Lounge 4 08-07-2006 01:05 PM
How to properly adjust Drive Belt tension ? markr01000 Camry & Solara Lounge 2 12-14-2004 08:07 AM
NO Seat Belt Shoulder Harness, NO Drive Toyota...HELP!!! MyCorolla Archived Corolla threads 8 12-13-2004 01:13 AM
