BAD fuel economy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 08:31 PM   #1 (permalink)
View fishbert's Photo Gallery
Gen5 BAD fuel economy
help
im new to the forum and im having problems with my 1990 celica.
basically im getting bad fuel economy, like 7mpg if im lucky. theres no fuel leak and the car runs fine but the exhaust fumes really smell.
ive had a mobile tune up guy out and he says the readings are well over the top to pass an emissions test but theres nothing he can do.
the ecu doesnt want to accept any changes and just adjusts its self back to whats bad.
im really stuck please help
fishbert is offline   Reply With Quote
Old 12-27-2006, 08:40 PM   #2 (permalink)
View DarkSideCelica's Photo Gallery
u might wanna be more specific..... wat's the exhaust smoke color? is the car running at normal temp always, or does it go up and down? did u do ur regular maintainence? tires properly inflated?
DarkSideCelica is offline   Reply With Quote
Old 12-27-2006, 09:06 PM   #3 (permalink)
ok the exhaust smoke is white and theres lots of it but other than that and the extreme use of fuel the car is running perfect. its been serviced well and looked after.
there was a short circuit on the ignition wire about 6 months back which blew a fuse a couple of times till it was fixed but even after that it was more economical than it is now, it just seems to be getting worse.
i dont know what else to put but ill answer everything as soon as i can.
Old 12-29-2006, 05:26 PM   #4 (permalink)
Does anyone have any ideas? its costing me a fortune on fuel.
cheers
Old 12-29-2006, 05:32 PM   #5 (permalink)
fuel filter, air filter, dirty TB, dirty EGR, pcv valve gone bad, etc... too many to list
as for the white smoke, u're getting coolant into the ignition chamber.... basically ur head gasket is going out and tht could be one main reason why ur mpg is so bad
Old 12-29-2006, 05:45 PM   #6 (permalink)
whats the EGR and pcv valve?
i really only get white smoke while the cars warming up then it seems to go away could that still be the head gasket.
ive only changed a head gasket on an astra, are they straight forward or a bit of a pig? cant be any worst than the clutch...can it?
thanks
Old 12-30-2006, 03:11 AM   #7 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Is your celica a ST or GT... 1.6L?
Blane is offline   Reply With Quote
Old 12-30-2006, 04:54 AM   #8 (permalink)
its the 2.0l gti 16v
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
engine braking fuel economy eatpan General Discussion 11 03-31-2005 09:01 PM
What is the REAL fuel economy of 05' Corolla CE/S/LE? SimmZ Archived Corolla threads 5 06-20-2004 07:03 PM
fuel economy uptownwest Archived Corolla threads 4 02-25-2004 04:43 PM
