i recently found a 90 st in excellent body condition motor has issues but other than that its in fine shape. ok one of my friends is in process of a 2zzge swap in his 03 gt, im thinking of buying his 2zzfe and whole setup, wiring, ecu, trans, all of it to swap into the ST has anyone ever done this? if so what problems can i look forward to from the start or later??
You could do it, but you will need to make 4 custom motor mounts, and some crazy wiring to start.
The ECU is going to go crazy because of your EVAP system for starters.
LOT'S of $$$ and custom work.
You are MUCH better off getting a 4AGE to stick in there.
Actually the swap wouldn't be that bad... if the tranny is still attached to the engine, then it will bolt right into the Celica ST, the only mount that *might* need some modification is the passenger side. The axles will fit right in, and the wiring I can take care of no problem. Exhaust, a/c and p/s is all that's left.
-Doc
A/C isnt one of my biggest intrests it robs power anyway, how long do you think it would take you to make me a wiring harness if i had both harness for the new engine and the original? and how much?
$350, I could have it back on it's way to you in less than a week.
-Doc
1ZZ-FE is a bolt on for 4A-FE engine bay? That's something new.
