'91 GT leaking masive amounts of P/S fluid?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2007, 05:46 PM   #1 (permalink)
Gameroom cash: $265140
View shortlid's Photo Gallery
Question '91 GT leaking masive amounts of P/S fluid??
My brother sold his '91 Celica GT to his girl with 100k+ on the clock. It is a GT coupe with 5 speed manual. He says about a month ago it started leaking the Dextron III ATF that he had been religious about changing every 15k or so. Seems to be leaking around the P/S pump area. He put Bars a leak P/S and auto tranny stop a leak in it and it slowed it but did not fix it. Is this likely a hose fiting or hose failure of a pump problem?
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
Old 01-01-2007, 08:21 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Most likely either the pump or the high pressure hose, which attaches to the pump.
The other end of the hose is right behind the pass side strut tower.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 01-01-2007, 08:29 PM   #3 (permalink)
ould you have a dig pic or diagram to reffer me to. I have the Haynes but it is in clear. Are the pumps $$$?
Old 01-01-2007, 08:33 PM   #4 (permalink)
Alltrack Wannabe
Haynes is junk....
For diagrams and the FACTORY manual go to www.celicatech.com
For parts try www.1sttoyotaparts.com or www.partznet.com
OEM is best, but not really cheap.
If you absolutely cannot afford, try Napa. They tend to have better quality than autocrap.
92 Alltrac, 85 PU
Old 01-01-2007, 08:36 PM   #5 (permalink)
Alltrack Wannabe
What did you do for TMMI?
92 Alltrac, 85 PU
Old 01-02-2007, 09:48 AM   #6 (permalink)
View Demonicpresence's Photo Gallery
mine did that bad there is actually a tad bit extra hose check the end going on the resevoir, i cut mine off put a new clamp on it and havent added any fluid for 6-7k miles.
Demonicpresence is offline   Reply With Quote
Old 01-03-2007, 10:41 AM   #7 (permalink)
AstroVannin's Avatar
View AstroVannin's Photo Gallery
Mine was leaking really bad when I got it. It was leaking from the cooler, its right in front of the rad. If that it you can just make a new one out of metal line from napa.
AstroVannin is offline   Reply With Quote
Old 01-03-2007, 04:12 PM   #8 (permalink)
"mine did that bad there is actually a tad bit extra hose check the end going on the resevoir, i cut mine off put a new clamp on it and havent added any fluid for 6-7k miles."
Thanks for the tip!
I worked for the Overseas ordering department for the Tundra. Bringing in engines and powertrain parts from Japan.
Old 01-05-2007, 04:50 AM   #9 (permalink)
View liplip's Photo Gallery
When i bought my 90 celica gt....the power steering fluid was leaking so much.All i needed was the high pressure hose connected to the pump and hasn't leaked since.
liplip is offline   Reply With Quote
Old 04-03-2007, 08:52 AM   #10 (permalink)
Question That is it, high pressure hose.
OK, we got under the car yesterday and the high pressure hose is leaking somewhere near the crimp fitting near the strut tower. Then leaking DOWN the insulation onto the pump. Would COULD NOT figure out how to remove the insulation, or even more importantly what size the bango bolt for the high pressure hose was on the pump? 21mm did not fit it must be like 24mm!! Also it is REAL hard to get back there!! We did get the high presure hose from O'Reilly for $30!!
Old 04-04-2007, 11:01 AM   #11 (permalink)
It wasn't me who fixed it, it was a family friend mechanic.I was watching him though and he just did it from the engine bay.He didn't take anything off and he just used tools to make it longer so it would reach.If the car has been driven, that area would be pretty hot so let it cool down.I haven't leaked in 6 months since it got put in.I'm having problem with a gas leak now and it will get fixed soon.
Old 04-04-2007, 11:51 AM   #12 (permalink)
Canada Can you or I ask him?
I need to know what size that banjo bolt is? Can you ask him or can I ask him? Also what tool did he use to get in there. It is a very difficult spot!!
91 celica gt gas mileage bluecelicagt Celica Forum 17 08-13-2011 09:31 PM
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 12:10 PM
??'s about the nver needs changing AT fluid kn38ms 2nd Generation (2005+) 22 10-29-2006 08:42 PM
'91 Celica GT. Need some advice Celica4life Celica Forum 10 05-13-2004 01:23 PM
Inspection of a Stock 91 Celica GT 2.2 Zrain Celica Forum 9 02-29-2004 05:57 PM
