3S-GE diagnostic codes 21 and 51 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2007, 03:06 AM   #1 (permalink)
Unco's Avatar
View Unco's Photo Gallery
i'm getting 21 and 51. it's a gen4 celica with a 3S-GE. according to the following website: http://www.toyotacelicaonline.com/error.htm it says the following:
21: 2, then 1 Oxygen Sensor Signal
51: 5, then 1 Switch condition signal
it does state, however, that those codes are for gen6 celicas.
is anyone able to confirm that the codes are the same for gen4 cars? also, what is a "Switch condition signal"???
TIA
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 01-05-2007, 08:40 PM   #2 (permalink)
Unco's Avatar
anyone?
Old 01-06-2007, 02:03 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
change the o2, clear codes and try it
Old 01-06-2007, 03:18 AM   #4 (permalink)
View toyomoho's Photo Gallery
Code 21 is 02 signal. Open circuit in 02 sensor circuit, bad 02 sensor or bad ECU.
Code 51 is signal switch. Problem with A/C switch, TPS circuit, TPS, neutral switch or ECU.
Old 01-06-2007, 11:20 AM   #5 (permalink)
Unco's Avatar
ok. thanks for the replies. i'll look into it.
Old 01-28-2007, 10:24 PM   #6 (permalink)
View kwando's Photo Gallery
i just got code 21... which o2 sensor is it? the one in the front? rear near the firewall? is there one by the cat???
kwando is offline   Reply With Quote
Old 02-01-2007, 07:24 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
what motor?
Old 02-03-2007, 02:35 PM   #8 (permalink)
3vz-fe
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-18-2006 12:06 AM
