Blew Timing Belt?? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2007, 05:44 PM   #16 (permalink)
View bashattitude's Photo Gallery
Once you have the mount separated lower the engine a little bit so you can get the belt out once you are ready to remove it... there are "tabs" sticking out of the bottom cover that have the screws holding it in place... you will have to remove the harmonic balancer as well. I am a bit short on time but if nobody has given you the timing mark locations by morning I will try to get them here for you... gotta go...
bashattitude is offline   Reply With Quote
Old 01-19-2007, 08:55 PM   #17 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
My uncle got the timing markings and everything for me so its all good. But once I get time Im going to try and finish this damn thing. I got the replacement belt. Only $18 :-p
Createdtoburn is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
