Car Is a turd - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2007, 06:16 AM   #1 (permalink)
View govtworkhorse's Photo Gallery
Exclamation Car Is a turd
Ok. I drive a 92 celica gt 5-speed and it is running like garbage now. First off, I have no power as far as engine goes. There is a loud humming noise coming from engine bay when I let off the gas or cruise at certain rpms. (2500) I have new plugs and wires. All the norm. Curious if anyone has had a similar problem. No engine light. No over heating. Seems like the majority of power loss is at but not limitd to higher rpms.
govtworkhorse is offline   Reply With Quote
Old 01-06-2007, 06:43 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Power loss or lack of power?
The 5SFE is weak up top.
It's designed for lower rpm power.
It won't hurt to do a good tuneup.
Which means no Bosch plugs or such.
Use NGK or Desno [OEM] stuff.
Plugs, cap/rotor, wires [if they need it].
How old is your oil?
How does the air filter look?
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 01-06-2007, 08:09 PM   #3 (permalink)
I have a new filter, oil, plugs, wires, head gasket, axles, and all kinds of stuff. (Yeah I kow some of those don't help but I was going through the list.) Anyway, it's more of a lack of power. Can barely make it up a hill. I thought maybe it was like some air flow sensor or something. Also has a problem with idle. Will idle normal and all the sudden kick up to 2k and stay there. Then when I take off it wants to drop off and die. I have to rev the shit out of it and drop the clutch. I'm baffled
Old 01-07-2007, 11:59 AM   #4 (permalink)
Alltrack Wannabe
Your ECU uses a MAP sensor.
It reads the pressure in the intake manifold. It doesn't read flow.
Have you checked your EGR valve?
It might be stuck partially open some times.
92 Alltrac, 85 PU
Old 01-07-2007, 12:12 PM   #5 (permalink)
Thank you. I will check that out and get back to you on the results.
Old 01-08-2007, 08:36 PM   #6 (permalink)
engineer in training
Gameroom cash: $141655
check the timing belt whoever did the head gasket might have let it slip one tooth on accident (it's easy to do)
Old 01-10-2007, 09:49 PM   #7 (permalink)
Alltrack Wannabe
If it's the timing belt off it should be a constant thing, not sometimes high idle and such.
But it doesn't hurt to check....
92 Alltrac, 85 PU
Old 01-11-2007, 01:53 PM   #8 (permalink)
eh you never know with these damn japanese cars j/k
Old 01-11-2007, 03:22 PM   #9 (permalink)
View OBwan's Photo Gallery
If its a 92, sounds like the Cat is clogged.
OBwan is offline   Reply With Quote
Old 01-11-2007, 07:03 PM   #10 (permalink)
View marc780's Photo Gallery
I'd do a compression check and/or an engine leak down test. Also a vacuum reading is simple and could help tell you if the cat is clogged.
these tests will give you a good basis to start with on this engine and if you get low compression readings you wont waste your time changing sensors and so on -
MKIV Scam registry bmw5002 Supra Forum 11 07-10-2010 12:59 AM
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 09:05 PM
FS: 92-96 Cheap lexus part out or whole car. ES300. winner007 Vehicles 0 08-16-2005 03:30 AM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 04:15 AM
Most customized camry i've ever seen..... Zeek321 Camry & Solara Lounge 68 10-15-2002 12:35 AM
