Ok my co-workers were driving an 01 GT when somehow they realized they had low or no oil, filled the oil and drove down the road... without putting the filler cap back on
. A while later down the road they lost power and disciovered this mistake. They went for oil, filled it again and now it dosent want to run. I have pulled the plugs and rotated the engine with a breaker bar, pistons rising as they should, no broken rods. Turning the crank by hand was a little tight to me but it just might be this engine (not much experiance with Toyota). When this car does attempt to start (maybey runs for five seconds) there is a knock. My best guess from here is that the engine almost sized up / maybey tweaked a rod / and or has worn the rings out all from oil starvation. I am saying a full bottom end rebuild, because that knock must be mechanical.
Now we dont know how to pull codes. They dont have a manual... like I told them to when they brought the car to MY HOUSE. Havent attempted a compression test yet. We disconnected the battery in an attempt to clear a code that may have put this car in limp mode but no luck.
Any help in geting this car away from my garage would be appreciated.
Thanks
Fry
