92 5S-FE Radiator Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 01:03 PM   #1 (permalink)
View maukiman's Photo Gallery
Gen5 92 5S-FE Radiator Replacement
So my radiator has a long crack long the top edge and has enough rust so to warrant replacement instead of repair.
2 questions?
1. Can I put a larger radiator in from say a Camry, or even a better after market rad?
2. What would be a good source?
I have search this forum - and didnt find too much in regards to both questions. I did see a lot of replacement rad on parts websites - but there are very few details provided. And as you can see from Q1 I would like to improve the cooling system since I am already gonna drop a few hundred into a new rad.
Thanks!
maukiman is offline   Reply With Quote
Old 01-16-2007, 05:58 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might check the Camry section, the same question came up (the car uses the same engine).
Old 01-16-2007, 07:06 PM   #3 (permalink)
toyomoho - thanks for the reply - I will take a look over there and the post back here (in case anyone else wanted to know).
Thanks again...!
Old 01-17-2007, 09:48 PM   #4 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Same engine, totally different chassis.
Don't bother.
A GTS or Alltrac radiator is thicker, so it would be a slight upgrade.
However, if you have an auto, the Alltrac rad won't work, as they didn't come in auto.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 01-17-2007, 11:01 PM   #5 (permalink)
engineer in training
Gameroom cash: $141655
if its auto just bypass the radiators tranny cooler altogether and put a large cooler on it by itself. Works just fine, my Camry has been like that for quite a while.
clear corner for 92 CamryOwner98 Tercel, Paseo, Starlet, and Sera Forum 2 05-23-2008 10:50 PM
92 Paseo No Spark - where to look? GeneralDisorder Tercel, Paseo, Starlet, and Sera Forum 4 05-02-2005 11:01 PM
92 Celica GTS Plat Celica Forum 7 06-21-2004 10:07 PM
92 Corollas??? rollaman Archived Corolla threads 11 01-24-2003 04:40 AM
