Celica Electrical problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2007, 08:38 PM   #1 (permalink)
View p_bassn's Photo Gallery
Canada Celica Electrical problems
Hey, I recently installed a subwoofer in the back of my celica, but when I tried to start the car it wouldnt turn over, but not catch. Ive checked the battery and the alternator, but nothing seems to work.
Please give me ideas on what I should check. I have an 1989 Toyota Celica GT-S.
thanks.
p_bassn is offline   Reply With Quote
Old 01-22-2007, 08:58 PM   #2 (permalink)
View toyomoho's Photo Gallery
Make sure the battery is up on voltage. Engine off should be 12.6-12.8V, if below 12V you have a problem. With engine on, the alternator should be charging the battery at 13-14V. Also check the battery cables for corrosion, damage, etc.
The alternator will put out about 70amps at a high idle. Make sure you new amp system is not drawing too much current at engine idle or when off and running down the battery.
Old 01-23-2007, 12:38 AM   #3 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
make sure you didnt short out any fuses
89CelicaGTTurbo is offline   Reply With Quote
Electrical Problems... need help/advice LebaneseCam Camry & Solara Lounge 9 07-27-2005 03:43 PM
83 Celica Supra GTS electrical problem MrPipes Celica Forum 3 08-14-2004 04:21 PM
electrical problems eyz closd MR2 Forum 7 01-24-2004 12:45 AM
HELP: Question on taillight indicator & other Electrical Problems!!! thisdj78 Camry & Solara Lounge 7 08-11-2003 11:31 AM
