Tdc - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2007, 05:20 PM   #1 (permalink)
View fishbert's Photo Gallery
Gen5 Tdc
hi
does anyone have a photo of the cams on a 1990 3sge engine at TDC?
ive just replaced the head gasket and was planning to do the cambelt as a second job and messed it all up. i cant find a pic of the cams at tdc.
i know the crank pulley position but i understand that it can be 360 degrees out as its a 720 degree cycle. i believe im halfway through that cycle as the dots on the cam are at the bottom. but im not sure what im supposed to line them up to. i cant look at a haynes manual cos they wernt produced in the uk so please any help will be greatly recieved.
thanks
Pete
fishbert is offline   Reply With Quote
Old 01-31-2007, 08:43 PM   #2 (permalink)
View toyomoho's Photo Gallery
There appears to be two types of cam pulleys, 5 holes (bolt holes) and 1 hole (actually no bolt holes other then the bolt that screws into the cam). If 5 holes the knock pin should be in the up position. If 1 hole, the keyway should be up. Each pulley appears to have an “S” and a view hole that should be up. Normally there is a mark(s) on the head somewhere at the top; each pulley hole is brought up and the mark sighted through the hole. Both pulleys will have the same alignment (view holes up).
The crank is brought to 0 degrees and the timing belt installed. Turn the crank two times by hand and recheck all marks. If off, try again. Remember, when the tensioner is released, the cams may rotate a little which may make the alignment off. If so, attempt to compensate by moving the cams one way or the other before installing the belt. If still having issues, post back a private message and I can send a diagram.
Old 02-03-2007, 06:01 PM   #3 (permalink)
cheers
i got it sorted now thanks, new H/G and a new ecu and the cars running like new, been driving about all day with a big grin on my face, i aint done that in a while.
thanks
Ignition timing problem, can't adj to 0 deg TDC. shandar Pre-88 Toyota Pickup/Hilux 5 01-30-2007 08:45 PM
Need help with timing belt tdc thao Celica Forum 6 08-07-2006 01:32 PM
timing belt, setting to TDC BobES300 General Lexus Discussion 6 03-03-2005 06:11 AM
TDC Problem Delo Camry & Solara Lounge 3 10-13-2004 06:44 AM
Question about TDC deviouschild Camry & Solara Lounge 7 09-10-2004 09:40 PM
