Wow, no replies. Oh well. Followinfg up....
On the outer part of the tail lamp (half moon area of the lens) there is a small pressure clip.
I just inserted a small screwdriver blade, inserted tip vertically on the lens half moon center, used levering motion, clip easily popped open. Again, the Clip is in the center of the half moon.
Too bad I broke a piece of plastic before finding out.
There are 2 more Phillips type screws that are exposed once cover is removed.
Then Tail Lamp assembly can be removed for bulb replacement.
