dude if your window fogs up from moisture your heater core is, infact, broken. check your coolant levels often untill its replaced. a temporary fix to this is to disconect the 2 hoses from the firewall and connect them togeather, by-passing the heater core. no heat, but no leaks. oh and if you want to test your gauge, turn the key on(not start) and ground out the wire on your temp sensor. if the needle on the gauge goes all the way to the top your gauge is properly functioning. grab a buddy and go test it, but most likely your gauge is fine.
