Anyone please help Me! 88 celica gt-s that idels rough under 2krpms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2007, 02:43 AM   #1 (permalink)
View jonny121986's Photo Gallery
4th Generation Anyone please help Me! 88 celica gt-s that idels rough under 2krpms
well i got new plugs and the cap is almost new. everything is getting spark. the 1 2 and 4 plugs were dirty and more white. the number 3 was straight black. they are all getting spark but it is running on 3 cylinders i can pull the wire of #3 and it wont change the car at all. that is how i know it isnt working. i dont have a pressure tester to see if it has a burnt piston or valve. is there anyother way to tell? does anyone else have any suggestions????? thank you ver much jonny
jonny121986 is offline   Reply With Quote
Old 03-02-2007, 11:53 PM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
How's your distributor? I washed my engine bay once and some water got in the distributor and shorted out #3 on my car.
There's my two cents.
Blane is offline   Reply With Quote
Old 03-03-2007, 02:43 AM   #3 (permalink)
thanks
well there is spark getting two it so wouldnt that mean that the distributor is good?
Old 03-03-2007, 02:46 AM   #4 (permalink)
View toyomoho's Photo Gallery
Is the number three plug getting spark? Pull it, reconnect to the wire, crank engine and see what you get. Crank engine with plugs in and distributor cap off. The engine should sound as if all cylinders are the same when they turn over. If the starter seems to accelerate at one point, a cylinder may have very low compression.
Old 03-04-2007, 12:53 AM   #5 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
also check the #3 injector. that cylinder might not be getting any fuel.
89CelicaGTTurbo is offline   Reply With Quote
Old 03-14-2007, 03:07 PM   #6 (permalink)
how's it going on the idles issue?
Old 03-15-2007, 11:48 PM   #7 (permalink)
View cobbo_8's Photo Gallery
hey i have the same problem with mine after changing a seal around the tappit cover, check the sensor behind the engine above the intake might be lose, other than that ive got nothen good luck
cobbo_8 is offline   Reply With Quote
Old 03-21-2007, 06:27 PM   #8 (permalink)
View customlifestylz's Photo Gallery
I had a similar problem just a month ago my car was idleing terrible and i replaced a lot of stuff that didnt help. Check you MAp sensor above the intake and see if dissconecting the vacum line changes anything and if so replace it. If not i had a plug wire that looked good but if you looked closely the side had split in the area thats down in the head, and was losing current strenght or something and needed to be replaced and that fixed it with replaceing my MAp sensor.
customlifestylz is offline   Reply With Quote
Just picked up a 88 Celica GT NJ88GT Introduce Yourself Here 0 01-07-2007 11:16 PM
Want Peddels for 2002 Celica GTS for 2002 Celica GT ashes Celica Forum 1 11-17-2003 11:24 AM
