i have a 91 celica st with the 4afe in it ... couldn't find a 4afe so had to go with the 5afe replacement... time was an issue as well as cost ... my question is what parts do i use? the timing belt .. which one goes on that engine? i've found absolutely no info ... is there anything special i need to do? keep in mind i'm doing this at home ... i've already swapped in a 4afe before but i'm unsure about this engine
also ... is the a/c compressor easy to change? i was going to wait until after the swap but if it's a pain i might do it while the guts are out
