fuel pump solenoid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2007, 02:20 PM   #1 (permalink)
View martin555sail's Photo Gallery
UK fuel pump solenoid
Hi Please can someone help I have a 1990 Celica Japanese import I am trying to locate the fuel pump solenoid and resistor. My pump isnt running but when checked on a battry it is ok. There doesnet seem to be a feed to the pump
Thanks
Martin
martin555sail is offline   Reply With Quote
Old 03-12-2007, 02:37 AM   #2 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
do you have an Alltrac, Gt or GTS?
89CelicaGTTurbo is offline   Reply With Quote
Old 03-13-2007, 04:31 PM   #3 (permalink)
Hi I am sure it iis the GT
Thanks
Old 03-13-2007, 08:07 PM   #4 (permalink)
i didnt think that the GT had a solenoid. when i did my swap i couldnt get my solenoid and resistor to work so i just hooked up the pump directly to the ignition.
Old 03-13-2007, 10:06 PM   #5 (permalink)
View toyomoho's Photo Gallery
What size engine, turbo or non-turbo?
Old 03-14-2007, 02:14 PM   #6 (permalink)
Hi
It is a 2 litre non turbo
Thanks
Martin
Old 03-14-2007, 08:11 PM   #7 (permalink)
This engine setup appears to have EFI Main and Circuit Opening relays between the fuel pump and EFI fuse. The EFI relay appears to be located in a fuse box behind the battery. The Circuit Relay appears to be next to the ECU, center console passenger compartment.
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
Walbro Fuel Pump, turbine pump? almc2242 Hardcore Tech and Competition 13 02-19-2005 09:08 PM
Bigger injectors/ Fuel pump in 4th gen 97camryman Camry & Solara Lounge 4 11-15-2004 05:48 PM
Fuel pump requirements for 5psi boost (carb'd 4a-c)? O 16581 72452 5 Archived Corolla threads 4 03-17-2004 12:00 PM
