93 celica fresh 3sgte swap no spark? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2007, 06:06 PM   #1 (permalink)
View insaneinsite's Photo Gallery
Well im near done with me 3sgte engine swap when i went to check the wireing i realized i had
no spark. so then i started to check into things, i have power to the coil and ignitor, and no
spark out of the coil so i assume it has nothing to do with the distributor. With the new
engine i got an altrac wireing harness and a ecu so i figure something might be shorted so
for kicks i put in the 5sfe ecu and got spark? so i figured maybe it was the ecu that is junk
but after doing some tests on imput and output on the coil and stuff with the 5sfe ecu i lost spark with that as well did i fry something or do i have other issues anyone have any input
on this problem?
insaneinsite is offline   Reply With Quote
Old 03-13-2007, 12:18 PM   #2 (permalink)
still no luck
Ok... I've been messing with this thing for the past few days and figured out a plugg was a
little messed up inside. So i cut the old one off the other wireing harness and put it on the
new one, now i have spark again with the 5sfe ecu. What does anyone think? bad ecu? ill
take any input i just wana hear this thing run
Old 03-13-2007, 02:00 PM   #3 (permalink)
View 86gtscaged's Photo Gallery
Go to
www.alltrac.net...
86 Celica GTS ....6 Point cage , Full suspension , 3sge with header, full exhaust with no cat...My new toy
99 Mustang Gt...Gears, Slp , 4cyl Coils,...she goes straight most of the time
86gtscaged is offline   Reply With Quote
Old 03-14-2007, 09:58 AM   #4 (permalink)
thanks
Well after searching around i found that the pin layout on a 91 3sgte wireing harness is a
little diff than one from a 92-93.. Nothing major just have to move a few pins around. May
be running today
Engine swap US 3SGTE 1991 > JAP 3SGTE 1994 - Pinout JesperDenmark MR2 Forum 12 03-20-2010 06:47 PM
3SGTE swap or 3SGE akujin MR2 Forum 9 05-17-2007 06:15 PM
3SGTE Swap LuckyGuess Camry & Solara Lounge 16 04-07-2006 04:43 PM
90 celica 5sfe to 3sgte swap 90_celica Celica Forum 16 02-08-2005 07:19 PM
90-93 Celica 3sgte performance upgrades! lyracon Celica Forum 6 02-03-2005 02:00 PM
