Smelling Fuel in Cabin - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2007, 12:08 PM   #1 (permalink)
View 89_3SFE's Photo Gallery
I've got an 89 GT (3SFE) and I can smell fuel in the cabin of the car when I run the A/C or the heat from fresh air outside. Also, I can smell it strongly when I smell right underneath the front windshield wipers with the hood closed. It sounds like a fuel leak, but I don't know where. It never leaks fuel outside and I never see any fuel dropping to the ground so if it leaking, I think it's leaking into the engine. But then, why do I smell it? Any ideas? Has anyone experienced this before?
89_3SFE is offline   Reply With Quote
Old 03-21-2007, 12:11 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Running the air cond or heater will suck air from just above the bonnet (hood).
If you have a small leak (just enough to cuase some vapours but not enough to cause visible spots on your driveway) then these vapours will be sucked into the cabin.
Might also be the fuel tank vent line in the boot (trunk) coming loose but you said the smell was towards the front.
- Stepho
stepho is offline   Reply With Quote
Old 03-21-2007, 09:35 AM   #3 (permalink)
View insaneinsite's Photo Gallery
You may also wana check you return feul line by the motor it might be leaking just when the car is running
insaneinsite is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Paseo Fuel Pump Question leeave96 Tercel, Paseo, Starlet, and Sera Forum 2 10-24-2006 11:40 AM
95 camry fuel pump connection questions dwmoss 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-24-2004 12:45 PM
