MAF Issues... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2007, 10:56 AM   #1 (permalink)
View flyinby's Photo Gallery
MAF Issues...
Quick question guys, i have a 91 celica w/ a 3sgte swap and when the gas is put to the floor the maf seems to be throwing a code causing the engine to run in limp. I know its the maf cuz i get out and unplug it... plug it back in and the engine runs fine until i attempt to give it some gas again, is there any way i can test this before i go replacing the thing?
flyinby is offline   Reply With Quote
Old 03-21-2007, 04:39 PM   #2 (permalink)
anyone have any info plz? i priced it and its $780...
Old 03-21-2007, 06:32 PM   #3 (permalink)
View customlifestylz's Photo Gallery
Did you use the 5sfe maf or 3sgte? And i would try ebay or a jukyard before buying a brand new one. The 5sfe one is 350+ at pepboys and i got two working ones at a yard for $10.
customlifestylz is offline   Reply With Quote
Old 03-21-2007, 06:56 PM   #4 (permalink)
View toyomoho's Photo Gallery
Sounds like what a bad MAF sensor would do. I wonder if you can spray Seafoam or other cleaners in there and see what happens. Can you find some service info, the MAF system can be checked using a voltmeter? The voltage will vary with airflow.
Try junkyards, web based dealers, Ebay, etc. Saw a MAF for a 3SGTE on a MR2 on Ebay.
Old 03-21-2007, 07:22 PM   #5 (permalink)
could 14lbs of boost cause this error?
Old 03-21-2007, 07:23 PM   #6 (permalink)
it is the 3sgte maf...
Old 03-21-2007, 07:57 PM   #7 (permalink)
I think the MAF uses a hot wire design. If so, doubt 14PSI would do anything to it.
Old 03-21-2007, 08:33 PM   #8 (permalink)
k thanks for the info
Group Buy for PSC1 (15 more HP) Pb 2nd Generation (2005+) 82 12-24-2008 10:33 PM
URD Maf calibrator installed. tacogrande 2nd Generation (2005+) 122 11-21-2007 03:23 PM
MAF Issues... flyinby MR2 Forum 6 03-21-2007 12:58 PM
17" mojave or chambers - any issues? baselfish 2nd Generation (2005+) 3 03-14-2007 05:46 PM
Cleaned MAF sensor, Check engine light on cheesycoolguy 1st Generation (1995.5–2004) 13 02-26-2007 04:16 PM
