A few suggestions. Is the rotor turning? Disconnect high voltage wire to coil. Hold wire end about ½ inch from chassis ground point and crank engine. If yes, for spark check at the plugs. If no spark check for battery voltage to the coil and igniter with ignition switch on (Black/Orange wire). If yes, check resistance of coil windings when cold. Primary 0.40-0.50 ohm, secondary 10.2-13.8 ohm. If OK, check resistance of distributor pickup coil 140-180 ohm and presence of air gap (0.008 inch).
Check wiring between ECU, distributor and igniter. The grounding wires appear to be Brown and White/Black.
