3s-gte is big time overrated, yes it makes numbers, but the amount of money put into the damn things outweighs the benefit of it just being a 3sgte. You can make the 4afe stock have just as much power with less cost than a 3s, and less work.
For the oil lines, any size will work for the return, just buy a generic ebay return kit and take your oilpan off, take it to a welding shop and ask them to weld it on about the top middle of your oilpan, as for oil feed just find a normal oil feed kit for a t3 turbo. You will need to either remove your oil pressure sensor and use a brass T to split the feed off or tap your block for the feed, I recommend doing it the first way I mentioned.
As for tuning, you WILL need upgraded injectors, the easiest to tune with will be the black supra injectors rated at 440cc, then use a 3s-gte map sensor. You will idle and drive fine in vacuum, as the 3s map sensor scales with the 440s perfectly.
You need tuning, if you arent looking at pushing more than 80 extra horsepower out of the engine just an SAFC will do, if you really want to optimize your kit you will need something that controlls the injector PW and the spark advamce, as well as a knock detection device.
A Greddy e-manage with injector harness and ignition harness will do everything you will need, or a PP SMT-6 or SMT-7 but they arent easy to come by, I know of a dealer and its the same cost as a new e-manage with the extra features.
