Emergency!!! Please Help! Engine problem! Something is broken and/or bent - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2007, 08:58 PM   #1 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Gen5 Emergency!!! Please Help! Engine problem! Something is broken and/or bent
My 1992 celica st 1.6L 4AFE pictured below is dying. The Engine had a knock... now it's super serous knock. I don't think it's a snapped rod. I think it is a bent valve lifter rodd or something like that.
My question is: Can I still drive with the bent valve rod?
I would like to know if I drive the car next week while the new replacement engine is on it's way next week. I am buying a 5afe to replace the engine.
Tomorrow I will be going back to work (where my car is sitting right now) and get video of the engine with the valve cover off. and run the engine.
BTW.... My oil is at the propper level. The engine has 239,300 miles on it.
Thanks for your help!!!!!!!!
You all are the best!
Blane is offline   Reply With Quote
Old 03-24-2007, 02:01 AM   #2 (permalink)
View toyomoho's Photo Gallery
Are you saying it might be a bent valve stem? I thought the valve train on this engine was overhead cam and the cam road directly on the valve shin/bucket. Other then making the noise how does the engine run. A bent valve or broken rod will cause the engine to run rough.
With engine running remove each spark plug wire one at a time. If the noise lowers or goes away you have found the problem cylinder. Might be a bad rod bearing pounding away. An engine can run reasonable OK with a bad bearing (for a while) but the condition will get worse over time. Use a piece of rubber hose as a stethoscope and attempt to run down the location of the noise, upper or lower engine.
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Really Weird Engine Problem... tre_03 Tercel, Paseo, Starlet, and Sera Forum 3 04-18-2006 07:18 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
Engine Problem!!! Mk1, 1989 help!!! mikeym MR2 Forum 5 04-22-2005 01:35 PM
