3SFE wont restart - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2007, 08:25 AM   #1 (permalink)
highwayman1956
View highwayman1956's Photo Gallery
3SFE wont restart
I have a 86' ST162R with a 3SFE motor. I can generally start the motor when it is cold and it drives well. Once I stop the motor, it will not start again sometimes for 3 to 24 hours. I have checked the fuel at the filter and it has plenty of fuel and pressure. It has spark (varying strength). I have changed the coil, plugs and rotor. Does anyone have any suggestions please.
highwayman1956 is offline   Reply With Quote
Old 03-30-2007, 05:12 AM   #2 (permalink)
highwayman1956
still at a loss with it, but.... I have found that the idle control valve under the throttle body makes a buzzing noise for a short time when the engine wont start and is silent when it will start. I have found that by pushing the ICV plug off and on a few times the buzzing will stop and the engine will start. I have cleaned the ICV out as it was siezed with carbon. I have checked the engine fault codes and it has only one code showing which is 11. can anyone peace this together???
Old 09-19-2007, 02:35 PM   #3 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
I wonder if you could get it to idle nice if you could pull the connector and the IAC would keep the engine idleing at the right engine speed... I wouldn't expect it to start without a litte throttle (while cranking) and while the engine warms up. Maybe it'll work...
ChevelleSSLS6 is offline   Reply With Quote
Old 09-19-2007, 03:49 PM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $263590
View Doctor J's Photo Gallery
Buzzing sound is normal. Code 11 is for power interruption to the computer. Check EFI relay wiring and connectors.
Doctor J is offline   Reply With Quote
Old 09-19-2007, 05:18 PM   #5 (permalink)
Gameroom cash: $147537
I had that for a while, it was my rusty coil. Car won't start when coil is hot.
89 3SGE / 3SFE interghangable parts 89GTS Celica Forum 12 07-10-2006 09:24 AM
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
Thinking of swapping 2vzfe V6 for 3sfe I4 es250nut Camry & Solara Lounge 17 07-29-2005 09:01 AM
Old 3sfe ECU incompatible with new 3sfe? Talisman Hardcore Tech and Competition 8 05-15-2005 03:27 AM
3SGE and 3SFE, lets get our heads together almc2242 Hardcore Tech and Competition 9 01-27-2005 03:58 PM
