maf to map sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2007, 01:10 PM   #1 (permalink)
View finalturismo's Photo Gallery
maf to map sensor?
i need help on converting my maf to a map sensor... any advice on where i should start?
finalturismo is offline   Reply With Quote
Old 04-02-2007, 02:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
The two sensors operate differently. Do a Google search to read up on sensor design, operation, system requirements and how they are used. The ECU is setup for one type of sensor, another type may not work or cause problems.
Old 04-03-2007, 01:13 PM   #3 (permalink)
toyota ecus are used on multiple cars.
From what ive read alot of ecus have the ability to read from a map but that function is never used.. simply because the car was not equiped. So my goal is to go mafless.... hks made a kit for it and it goes for about 500 on ebay... iam trying to find somthing alot cheaper tho....
Old 04-03-2007, 01:58 PM   #4 (permalink)
The ECU may be able to read the MAP but is its programmed able to react to what it is reading. How does the ECU know it is now connected to a MAP instead of a MAF. I think the signal coming out of both is just a variable voltage, but could be wrong.
There are a few books out there the go into the detail of these system and setting them up. Can you somehow get the installation instructions for the HKS system.
Old 04-03-2007, 05:10 PM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
There's no point.
Unless you're blowing a turbo through it at very high outputs. That MAF is the least restrictive thing about your entire engine. Except maybe the valve size?
AIM/Yahoo Toysrme257th
Now with Turbo!
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 02:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 12:01 PM
