check engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 12:50 PM   #1 (permalink)
View jfs9900's Photo Gallery
check engine
Can someone tell me what fuse to unplug to disable the check engine light in my 2003 Celica??
jfs9900 is offline   Reply With Quote
Old 04-05-2007, 01:05 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might be the Gauge fuse but this would also disable other items. The better method might be to remove the bulb.
Old 04-05-2007, 02:18 PM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Why not just fix the problem. The cars computer turns on the light for a reason. You could take the bulb out, but im sure they must do emission testing in your area and you will never pass the test if there are codes in the system or the light dosent work.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 04-19-2007, 07:53 PM   #4 (permalink)
Electromagnetic Wave [:-h
2way's Avatar
View 2way's Photo Gallery
Yep... can't disable it... however.... pulling the EFI fuse or disconnecting the batt. will reset it.
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback Wagon '82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
2way is offline   Reply With Quote
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 08:52 AM
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 02:52 AM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 10:19 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-06-2006 12:28 AM
Check Engine Light on 98 corolla 240meowth Archived Corolla threads 0 07-24-2004 06:55 AM
