r series to an a series - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2007, 03:07 PM   #1 (permalink)
View treeninja's Photo Gallery
3rd Generation r series to an a series
hey i got a 3rd gen gts im looking at some motors now how closely does the r series come to the a series motors my 3rd gen looks super close to an86 corrola are they on the sme frames or completly diff cars does anyone know of any motor swap walkthrougs/guides as for swapping out the 22r for somthing bigger like a 4 age or 3s ive looked no one can give me a straight answer as to weather theyll come close to fitting or not i got all these people telling me to do reserch i just cant find anything on a 4ag swap to replace that 22r any help would be awsome thnx
treeninja is offline   Reply With Quote
Old 04-11-2007, 01:58 AM   #2 (permalink)
RA28 + MX73
View stepho's Photo Gallery
This might help a little.
http://ourworld.compuserve.com/homepages/stepho/engcodes.htm#Crossmembers
The 4A-GE (or even better 4A-GZE) and 3S-GTE definitely fit because plenty of people have done it.
Unfortunately I don't have ready access to one to walk you through it.
Usually once you've made up a set of custom engine mounts, the rest is pretty easy.
Here in Australia we usually use a gearbox and bellhousing from a 1981-85 ST140 Corona (which has a 2S engine).
I think the engine crossmember is also a direct bolt in but I'd have to double check that the next time I go to a wrecking yard.
- Stepho
stepho is offline   Reply With Quote
Old 04-11-2007, 02:15 AM   #3 (permalink)
RA28 + MX73
Oops, my webpage is down for some reason.
I'll try to fix it tonight.
- Stepho
Old 04-11-2007, 09:36 PM   #4 (permalink)
DCM
One with the farce
View DCM's Photo Gallery
4AGE bigger than a 22R?? The 22R is a 2.4 liter and the 4AGE is a 1.6 liter. That's 800cc's of displacement. I hardly think an A-series engine would motivate your car to any great speed, as it will have to work hard to move a bigger car. Your best bet would be to modify the 22R with a hot cam and bigger exhaust, or even swap over to a 22R-TE (turbo).
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 04-12-2007, 12:19 AM   #5 (permalink)
RA28 + MX73
Agreed, the 2400cc 22R (or turbo 22R-TE) would give him more grunt than an NA 1600cc 4A-GE.
A supercharged 4A-GZE would have similar grunt to the 22R but has the hassle of swapping engines.
A 2000cc 3S-GTE has the most grunt but of course also has the most complications. If I remember correctly, the US never got the ST140 Corona that you need to get most parts from (Australian wrecking yards are littered with the ST140).
The turbo 22R-T is probably the simplest performance upgrade (same mounts, gearbox, etc) but the stock 22R-T only has a small amount of boost (meant to be a truck motor, not a sports car motor).
If you want to go whole hog, the Lexus 1UZ V8 fits in.
Clearance for the exhaust manifold is a pain.
You will need to make custom engine mounts but that's not hard.
Not sure if the transmission tunnel is wide enough for the Lexus bellhousing.
I was halfway through this with a TA45 but stopped when it got complicated.
http://ourworld.compuserve.com/homepages/stepho/mods.htm#CarinaV8
(web page is down at the moment but will come up again in a few days)
- Stepho
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
ARCA series also OKs the Toyota Camry for competition in 2007 RAV4EVR Toyota News 1 11-03-2006 06:13 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-18-2006 12:14 AM
2006 Scion xB Release Series 3.0 (official) dlundgren Scion Forum 0 01-06-2006 02:14 PM
4agze into a 95' Prizm RadRacer3 Archived Corolla threads 58 11-17-2005 06:32 PM
