2003 Celica GT Belt Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2007, 11:46 AM   #1 (permalink)
View jkon's Photo Gallery
Does anyone have any info/pictures on changing the drive belts (not the timing belt). I am trying to locate where to take the tension off to remove the old ones and install the new ones. Thanks.
jkon is offline   Reply With Quote
Old 04-19-2007, 07:26 PM   #2 (permalink)
Electromagnetic Wave [:-h
2way's Avatar
View 2way's Photo Gallery
Pick up a breaker bar... a standard ratchet won't fit in there... and it takes alot if you use a wrench... w/a breaker bar... its a 1 man job. If you look at the tensioner bracket... you'll see a "nut" that's molded onto the bracket... you put the socket on that & w/the breaker bar you'll be able to leverage off the tension.
Go with a Goodyear Gatorback belt
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback Wagon '82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
2way is offline   Reply With Quote
Old 04-20-2007, 06:08 AM   #3 (permalink)
Thanks
Thank you very much. Will proceed this weekend.
Old 04-20-2007, 09:46 PM   #4 (permalink)
2way's Avatar
19mm socket... preferrably six sided...
I just pulled mine off tonight... was gonna change it... but, its in good shape.
Definitely go with a Gatorback belt... especially if you have the typical squealing problem. Gatorback puts an end to it. The one I just inspected has around 50K on it... looks fine & still no squealing
2002 Celica GT have timing chain or belt?? prozerran Celica Forum 2 03-22-2007 10:39 PM
Belt change interval? kamrhee 1st Generation (2001–2007) 5 07-28-2006 11:38 AM
emissions help - 92 celica gt obpTR Celica Forum 4 07-15-2006 02:41 AM
81 Celica and Timing Belt GregAt99 Celica Forum 3 05-10-2003 01:09 PM
