Just bought 94 st smoking but no oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2007, 07:52 PM   #1 (permalink)
View SUPERPAC's Photo Gallery
The car is smoking alot but is not leaking from the undercarriage of the car.What is my first step in fixing the problem?The oil had not been changed for about a year before i bought the car so it was very low and had not been driven alot.what about an engine flush 2 start?
SUPERPAC is offline   Reply With Quote
Old 04-21-2007, 09:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
Suggest first changing the oil and filter. Is this oil or gas coming out the back, take a whiff and see. Do compression or leak down test of the cylinders. After testing each cylinder add a little motor oil to the cylinder, crank engine and test again. Bad rings, scored cylinder should pickup compression with the addition of oil to seal them. If no change, might be valve guides or seals.
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
'94 Prizm eats oil Blue Scapegoat Archived Corolla threads 4 07-22-2006 10:42 PM
changed oil, now my car leaks oil mofojordan Camry & Solara Lounge 3 11-29-2003 10:49 PM
What I found when changing the oil. Kooter Camry & Solara Lounge 2 10-19-2003 06:37 PM
