Sunroof Control Relay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 11:31 AM   #1 (permalink)
View Tryzik's Photo Gallery
Hi,
I have an 86 Celica GTS and I am having a problem with the sunroof where it will slide open but not close. I checked the continuity on the switches and they all seem to be working. Also, after removing the headboard, the motor seems to work in both directions when voltage is applied.
I'm guessing the problem is a faulty control relay (unless the limit switches are the problem. I wasn't sure how to test them.)
If I am right about the problem, does anyone know where I can get a sunroof control relay fairly cheap?
All help is appreciated. Thanks!
Tryzik is offline   Reply With Quote
Old 05-10-2007, 11:25 PM   #2 (permalink)
View Kiasis's Photo Gallery
4th Generation
I recommend you try www.celicatech.com . I've never gone un-helped on that site.
My 88 GTS Toyota manual says (and I don't think there is any difference between our years for the sunroof):
No. 1 limit switch
Continuity between terminals 1 and 4 when ON and no continuity between T 1 and 4 when OFF
No. 2 limit switch
Continuity between 2 and 4 when ON and no continuity between 2 and 4 when OFF
In both switches, terminals are 1-4 counterclockwise starting w/ the terminal in the upper right if you are looking at the switch w/ the connect on top.
Replace any switch not to these specs.
The test instructions for a faulty control relay are longer, but let me know if you want me to copy them from the manual, too.
Kiasis is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
ABS pulsing poker838 Camry Hybrid 20 03-08-2007 10:07 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
