Will help you this? It's from manual.
Disconnect the suction hose from the cooling unit outlet fitting.
Disconnect the liquid line from the cooling unit inlet fitting. Cap the open fittings immediately to keep the moisture out of the system.
Remove the grommets from the inlet and outlet fittings.
Remove the front door scuff plate and glove box assembly. Disconnect all necessary connectors and the air conditioning harness.
Remove the cooling unit attaching nuts and bolts. Remove the cooling unit from the vehicle.
Place the cooling unit on a suitable work bench and remove control amplifier, relay assemblies or power transistor assembly, as equipped.
Using suitable tools, remove the upper cooling unit case clamps and retaining screws. Remove thermistor with thermistor holder.
Remove the lower cooling unit case from the evaporator. Remove the evaporator from the cooling unit.
Remove the heat insulator (heat sensing tube) and the clamp from the outlet tube. Disconnect the liquid line from the inlet fitting of the expansion valve.
Disconnect the expansion valve from the inlet fitting of the evaporator. Remove the expansion valve.
NOTE: Before installing the evaporator, check the evaporator fins for blockage. If the fins are clogged, clean them with compressed air. Never use water to clean the evaporator. Check the fittings for cracks and or scratches and replace as necessary.
