When my car has not run for a while (>12 hours), when I first start it up, the engine idles rough and then dies. If I re-start it and hold the accelerator down enough to maintain about 2,500 rpm's for a couple of minutes, the engine then stays running. Once it gets warmed up, it seems to run fine.
I just replaced the plugs (plat) and wires less than 25,000 miles ago. Could this maybe a fuel filter problem? If so, how hard is it to change one in a '94? (The "check engine" light has not come on either.) Any feedback would be much appreciated.
