3sgte swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2007, 01:11 PM   #1 (permalink)
View $TRD's Photo Gallery
3sgte swap
hi i'm thinking of swaping a 3sgte engine on my 96 celica gt but i want to use the same tranny from the 5sfe since the 3sgte is awd they told me i can use it but i have to weld the back part of it so what would i need to complete the swap
3sgte engine,ecu,wiring harness and what kind of clutch would i need to put in it ,is that all i need for the swap.
Thanks and please reply asap.
$TRD is offline   Reply With Quote
Old 05-20-2007, 10:36 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Use the stock GT tranny, and the 5S flywheel with a high performance clutch. The bolt holes on the 5S flywheel need to be drilled out just a little bit for it to fit. You do NOT want to weld the AWD tranny.
And you're going to need a wiring harness conversion, which I can do for you.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 05-21-2007, 10:41 AM   #3 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
check out www.6gc.net and they will be willing to help you out so much
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 05-22-2007, 06:37 AM   #4 (permalink)
yes i heard of phoenix tuning they are pretty good but what else would i need for the swap
Old 05-22-2007, 09:30 AM   #5 (permalink)
The Mad Scientist
Besides the clutch setup, you need a front-mount intercooler and piping, and I recommend a fuel pump though not required, and of course getting the exhaust set up.
-Doc
Old 05-24-2007, 06:45 AM   #6 (permalink)
ok and i want to put a greddy e-manage engine control unit would you be able to put does plugs in the harness and how much will it be
Old 09-24-2007, 06:10 PM   #7 (permalink)
View klone1000's Photo Gallery
Hay guys its been a long time. Since the 5sfte have cracked all 4 pistons, i have buy a 2nd gen 3sgte to go into my 1992 toyota celica gt. My question is does the 3sgte clutch work with the 5sfe transmission? In the rush to get the engine in i just bolted the 5sfe transmission on to the 3sgte using the 3sgte clutch and the 3sgte pressure plate. I then got worried so before i continue i want to make sure i done it correctly.....
klone1000 is offline   Reply With Quote
Old 09-24-2007, 06:42 PM   #8 (permalink)
The Mad Scientist
No, you need a custom clutch disc using the 5S hub on the 3S disc. I have them in stock, give me a call at 404-474-4573 or email, drtweak@phoenixtuning.com
-Doc
Old 10-03-2007, 12:09 AM   #9 (permalink)
Whats a User Title?
View Deezz_Nuttzz's Photo Gallery
Dr Tweak,
May I ask why you said that the AWD is NOT a good idea for a swap in a 6gc?
'06 GTI & '99 Celica GT
Deezz_Nuttzz is offline   Reply With Quote
Old 10-03-2007, 01:40 PM   #10 (permalink)
The Mad Scientist
Originally Posted by Deezz_Nuttzz View Post
Dr Tweak,
Do you mean welding the AWD tranny? That's not how it was designed to work, I don't know of anyone who successfully did that. It is possibly to convert the AWD tranny to FWD using parts from an MR2 E153 tranny, but with all of the parts that you need, you might as well just get an E153 in the first place, except for some special circumstances.
-Doc
Old 10-07-2007, 10:45 PM   #11 (permalink)
View A Diddy's Photo Gallery
I recommend u get an e153 tranny (v6 camry or mr2..some mr2 have lsd so even better) and use a 3sgte clutch. It has treated me very well to date.
2004 G35 6MT
1991 3sgte Celica GTS
A Diddy is offline   Reply With Quote
Is it possible to swap a 3SGTE into a 95 celica st shorty0o29 Celica Forum 7 09-06-2006 03:17 PM
mklll with a 3sgte swap? tamalpro MR2 Forum 0 01-21-2006 07:11 PM
mr2 n/a to 3sgte swap Fareal619 MR2 Forum 1 01-12-2006 12:48 PM
3sgte engine swap vs 1mzfe turbo KamryStylez 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-08-2005 12:59 PM
