Depends. How much oil does the engine burn? How is the compression? Worn valve stem seals are a very common problem on Toyota’s. As the seals age, they harden. If the car sits for a few months, the seals can also start to leak.
These seals can be replaced, usually by taking the head off. At the same time most owners opt for a valve job done. If you are doing the work yourself the cost is say $300-400 for a valve job, new guides, seals, etc plus gaskets. If a mechanic does the job add 6-7 hours of labor to this cost.
If the seals are the problem, replacing them can completely stop the smoke issues. Also do a TN history search on this issue (worn valve stem seals) as it has come up frequently.
